Using a DVI to VGA Convertor on a Mac mini-DVI to DVI convertor for my MacBook
20 May 2007
Hey everyone
I just brought an adaptor to use my macbook on monitors and projectors, now I know that VGA is the standard and DVI is for better quality, but since my monitors are DVI capable and I had a DVI to VGA convertor with them I figured if I bought a mini-DVI to DVI convertor from the mac store I could use the DVI to VGA convertor to use on all computers.
Problem is the convertor that came with my graphics card has 4 extra lil pins on it around the horizontal pin which isn't on the DVI part from the make store so I can't put them together.
Does this mean that the mini-DVI to DVI convertor can't then be used with another convertor to get it to work with VGA?
Gaunt
So there is no way I can get this DVI convertor from the mac store to work on a VGA output??
If that is so, that majorly sucks!! lol
Cheers for the reply
Gaunt
Nope, definitely can't do it. This was going to be my plan, but I've not needed a DVI one anyway so never had to buy the extra adapter.
Yeah unfortunately while it would have been incredibly easy to make a Mini-DVI to DVI-I adaptor, Apple didn't feel like it, so you have to buy both.
