Using a “flash bios” USB port?
28 Jan 2011
Just curious if it’s safe to use a USB port that’s for flashing the BIOS, as an ordinary port?
Or should it only really be used for flashing?
Yes it's fine.
Once you've flashed it via USB drive I'd reformat the thumb drive back to normal just to make sure you can't accidentally try to reflash the bios.
