bethere have supplied me with their bebox and a fairly short cable (1m, 0.5m? didnt really check) with rj11 connections on both ends to plug into the router/adsl splitter.
i've read about how its best to plug the router into the master socket and not to use an extension as it eliminates internal wiring as a reason for affecting speeds. theres a chance i might need to locate the router further away from the master socket than the supplied rj11 cable allows.
as i want to use the master socket, i've seen on the net, a 20m rj11 to rj11 cable, that would work, wouldn't it as in theory, i would still be connected to the master socket, just with a longer cable, right?
any problems in using a longer cable for what i need? (like how cat5 hits the limit around 100m)
