Using a Pocket PC as a WiFi dongle?
  • Thread starter Thread starter Vai
  • Start date Start date
Vai
Vai
18 Oct 2002
I have a laptop with no internet access (no wifi card), but I have a Pocket PC which can connect into the WiFi fine, and access the internet. I can connect the Pocket PC and the Laptop together with the USB cable. I want the laptop to access the internet through the Pocket PC's WiFi connection.
I know there is a similar setup for using a mobile phone to dial up to the internet, however I have googled and can't find any solutions that would connect using WiFi.
Does anyone have any suggestions? Thanks :)
You would need some sort of internet connection sharing (ICS) built in to the PDA but unless you can find it on the net i doubt it is possible.
