Using a seperate video card for physx?
13 Dec 2002
Newcastle upon Tyne
Im not sure if its possible or not but I have a 285GTX as my main card, and I have a spare 9600gt sitting in my drawer, could I use the 9600gt as a dedicated physx card? If so how do you go about it?
If you have a second PCI-e slot running at atleast 4x, 8x better, then yeah chuck it in and you can use it for dedicated physx processing... tho not sure if you can do that on vista, deff. works on XP or Win 7.
yeah ive got a spare slot, board is sli capable too so there both 16x i think, running win 7 atm aswell, do I need to use the sli bridge?
No don't use the SLI bridge (prolly won't fit anyhow).
EDIT: The SLI bridge is to communicate rendering data between the GPUs, PhysX works at an earlier stage and replaces the CPU in calculating where objects would be on teh screen before handing it over to the GPU to render said objects at their respective positions.
No need for SLI bride, just stick the 9600 in.
Then make sure the 9600 is selected for physx in the nvidia control panel
cool thanks for the info :) I probably wont notice the difference as Im not sure ive got any physx games but its just sitting there doing noting :)
And soon it'll be doing nothing, but using power and costing you electricity :p
There's not a single game a GTX285 can't handle the physx on, adding a 9600 will give you a few extra fps in a few games, whilst using power, generating heat, and adding to your leccy bill :)
Winter is coming! :cool:
Depends if your board is dual x16, 1x16+1x8 or anything else...
If you have either of those two, you're good to go. You'll actually lose speed if you have a board that has "either 1x16 or 2x8"... I have no idea if this happens for SLi, but I know in my crossfire board (although i currently just have one nVidia GTX260 in it) has a setup like that. Crossfire would actually slow me down in a way, as far as I know.
Sorry to hijack the thread, but does anyone know if there is a benefit to having 2 ATi graphics cards running Crossfire in 2 PCIe x6 @ x8 bandwidth slots?
