Using a single Windows 8 Licence twice on the same machine
8 Nov 2006
Ireland/Northern Ireland Border
I have a legit licence for Windows 8 Pro. (One of the cheap pre-release keys)
At the moment I use it in a VMWare Fusion Virtual Machine on my iMac.
I use Windows 7 under bootcamp. Can I use the same licence to upgrade my bootcamp partition to run on Windows 8?
You will probably only have 1 of those 2 installs authorised as the VM will emulate a certain amount of hardware making it look like 2 different machines.
I think a Windows client license gives you the rights to run up to 4 copies of that same OS as virtual machines on the same host as the client license applies to. Not sure if this changed with Windows 8, Microsoft are extremely vague about it as usual.
Basically it works like this....
1. Would you like to activate on the Internet?
2. Erm no thanks Ill ring Microsoft and activate by phone.
3. Have you installed the OS on more than one PC, well no.
4. Punch in very long code from MS and your done.
That was the case with Server 2008 R2, but not clients.
Have you read the EULA? Get the run box open and type EULA.txt
To expect home users to pay multiple "Windows tax" for essentially testing and learning is a little harsh imo.
If you have multiple physical pc's then fair enough cough up, its not as if a domestic user is running a commercial enterprise for profit. £80 quid for a rubbish OS is hard to swallow, fortunately I availed of the £15 quid offer for a rubbish OS so don't feel too hard done by :)
Did this.
Also looking at the software, and any Windows OS from XP up supports RAID. RAID Mirror is basically two identical installations of windows on two hard drives on the same machine and that is not illegal and you are using them at the same time. This may sound simple but is in the Eula.
