- 24 Sep 2007
Hi Guys
I am a web developer and use all the usually stuff, Dreamweaver, graphic design programmes, photo editing, Office, e-mail etc. Is there software good enough to create a virtual machine and run all of these stuff inside it, with the same (or pretty near the same) performance levels as if I was just using the OS normally. I want to make my work environment crash proof and easy to transfer to a new computer. If I could use a virtual machine, this would be ideal, because I could then just save everything in it and if necessary port my whole software setup to a new machine instantly.
If it is possible:
- What software should I use.
- What hardware do I need to make sure everything will run smoothly and I have enough space to save everything.
- Can I use a multi-monitor setup with a virtual machine too?
Thanks for any help, however brief.
If it is possible:
