- 17 Jan 2006
Hi,
I format my PC fairly often and want to know if this would be made easier if I used Acronis True Image Home 2009?
To install XP on to my SATA Raid HDs I need to add the driver at the pre-install section (F6?). If I had the image created once with Acronis would I then be able to bypass this whole section?
I only have a trial version of Acronis TI at the moment so i'm not sure of how this software works. I assume you make a bootable CD and then copy the image you have created to the main drive using it's utilities?? If so will I be able to do this from my external USB 160Gb hard drive?
