Using an IF statement in Excel
6 May 2009
I have this formula in excel
=((C5+E5+G5)-(B5+D5+F5))/(B5+D5+F5)
When I use the autofill it populates the column with
=((C6+E6+G6)-(B6+D6+F6))/(B6+D6+F6) 7,8,9 etc correctly
How would I go about using an IF statement to make it not show -100.00% in the cells in the column? -100.00% is a value that is worked out when no figures are entered into C5, E5 etc. When figures are present it changes.
I would like the cells to simply populate with the formula but not show any number until figures are entered.
Im not great with excel or maths in general unfortunately
Thanks
IF(C5<>"", ((C5+E5+G5)-(B5+D5+F5))/(B5+D5+F5), "")
This says: If C5 is NotEqual to Blank, then apply Formula, Otherwise keep cell Blank
You should be able to expand this to do what you want.
