Using an IP Address to Find a PC on a Network
26 Oct 2004
Up North
Hi. We've had a computer 'mis-used' on the works network and we have the IP address of the offending machine. Is there a way we can use this IP number to find the computers name, so that we can then check its history to see who commited offence. Unfortunately the machines are named 1-500, but we can tell by the name where in the building the machine is located.
Thanks.
if you check your networking equipment there is usally a button that shows all connected computers names and their associated ip address'.
edit: in the router/switch control panel.
Bash said:
nslookup if your using DNS.
Best way, but if you using DNS you can also usually get name resultion through the ping command as well. There's many ways to do it but i'd use nslookup.
Burnsy
