Using an LED TV as a monitor problem :(
15 Nov 2003
Hampshire, UK
Hi,
I'm trying to run my PC into my tv, but having an odd issue.
When I turn on the tv, it sees the bios screen, then goes blank and says no input. I've tried plugging in a monitor and manually setting the display to the native of the tv, but that hasnt helped.
I've tried a couple of cables, just to be sure.
Any idea why it won't display the desktop or windows login screens, but is happy with the BIOS?
the tv is set to auto, so will swap to whichever input resolution, and works fine whith bluray and xbox1.
Thanks for any help in advance.
