Using and upgrade disc.. How to boot and intall NEW O/S ??
3 Aug 2003
UK
Using an upgrade disc.. How to boot and intall NEW O/S ??
I can't seem to install my XP Pro upgrade disc (from xp home) as a standalone operating system.
All it wants to do is add XP Pro to the existing software and therefore turn the pc into a dual boot machine.
This isn't what I want. :mad:
I want a clean install. :(
Help!
Andy
Change the boot order in the Pc's BIOS to CD then HDD. Boot from the XP Pro disc and start the install. it will ask you to place a qualifing disc in the drive to check that you are entitled to install the upgrade version. When you have done that continue the install as normal.
Xp home is on a recovery cd rather than a standalone disc and reading up on it further it does indeed look like it can't be done.
So two other choices..
VISTA
or
X64
Both standalone original discs..
I can't see ECUTEK software being vista compatible though
