Using Ball Valves in-line
6 Jan 2013
Rollergirl
I came up with the "genius" plan of ordering some ball valves to make it easier to change out GPU's. Basically, a ball valve on the in and out so that I can simply close both and isolate the card from the loop.
However, when I look through the valve I realise that the hole is a fair bit smaller than a 13/10 fitting. Is this deceiving? Can I expect flow restriction to be minimal?
This is the valve:
https://www.overclockers.co.uk/showproduct.php?prodid=WC-060-AQ&groupid=962&catid=1529&subcat=2588
That particular one is indeed rather low flow. There are others that offer higher flow (larger hole), bitspower has one, unsure if ocuk stock it.
g/14 fitting same as all the other components in the loop
Yes, I was thinking surely they must be tested for a minimum flow rate?
Those fittings have corrosion issues, which is why I have avoided.
