Using BOTH the DVI and VGA Input ?
19 Dec 2002
My AG Neovo F-419 has both a DVI and VGA input.
Is it possible to plug a PC into each input and switch between the two via the monitor menu system / Anyone know ?
As said, it should work. If it does, its great. Ive got my main pc hooked up via DVI to my Dell2405, with the server hooked up via VGA. So to view the server, I simply have to press 1 button. Slightly OT, Baddass(or anyone else for that matter), do you know if its possible to get the picture in picture working with DVI and VGA? I can only seem to get it working with DVI and one of the other inputs.
