- 15 Feb 2009
- Bristol
Asked this in the photography section but got no answer so i'll ask here
So i received the Sanyo CG10 camcorder, but (initially) the battery doesn't seem to last long. I was thinking of buying another battery just in case i'm out somewhere and i run out of juice. The official Sanyo DB-L80 battery has a capacity of 740mAh.
I'm wondering whether it will be ok to put in a DB-L80 compatible 1300mAh battery (Pentax D-LI88)? And will it last double the time than the 740mAh? Or should i just play it safe and get another DB L80 battery? They are priced the same (give or take a quid).
