Using computer name/DNS rather than IP address
28 Sep 2004
London
My workplace already has 3 windows/linux servers up and running which can be connected to within our LAN (for telnet, http admin and ftp) simply using their computer names.
I've just added an old Power Mac G4 running as a basic fileserver but so far can only connect to it using its IP address. The server.local name established in system preferences doesn't work on any other machines on the local network.
Is there a way to do what I'm looking for on Mac OS X?
How do I go about doing that? My router/dhcp server doesn't have any options regarding DNS, is it a local machine setting?
Thanks!
I'd be interesting in knowing this as well. In my router I have ip addresses mapped to individual machines on the LAN but I still cannot remote desktop from mac to pc using pc name.
See in your work, are you running a DNS server? Does the Mac machine need to use a fixed IP address, can it not just use DHCP?
Thanks!
Of course your router doesn't have DNS options*. You need to add the machine to your DNS Server which will more than likely be running on one of the servers as a service.
Once you have found where it is you just need to add a host that points to your G4**
* Assuming your router isn't a software router (one of the linux machines?) and is also a DHCP/DNS server!
** Static IP address only.
Go to System Preferences > Network
Choose advanced..
Then add it in, in this window..
I've done it the hosts file way, which works great since only one machine really needs it. We don't have a dedicated DNS server (a software router/firewall/DNS server is on the cards next), just a rack-mount router.
Thanks!
I added the pc name to the hosts file but i still cannot remote desktop from mac using machine name
Is the PC DHCP assigned? To use the hosts it would need to be static.
Thanks!
You don't have DNS? Any reason why not? You have some Linux servers so setting up DNS wouldn't be too difficult and would make life a little easier...
It certainly would, but they're Aspera delivery machines in constant use, I don't have root details nor do I really want to start mucking around with them.
