Using crossover cable with router
6 Jan 2006
Midlands
Hi
im using a crossover cable at the moment to connect two computers together.
Im gonna purchase a router soon and i was wondering can i still use the crossover cable as a normal cat 5 cable and plug it to the router.
if it works, it will save me a few bucks.
As said above, if the ports on the switch aren't autosensing wont work. You need a straight thorough patch cable to connect PC to switch, or a X-Over to connect PC directly to router
ok, guess i have to actually try it out before getting more cables.
thanks for the replies guys
