Hi all,
I've used link below to setup the D-Link DIR-868L Router to be used as a Wireless AP.
• Disable UPnP™
• Disable DHCP
• Change the LAN IP address to an available address on your network. The LAN ports on the router cannot accept a DHCP address from your other router.
http://www.dlink.cc/d-link-router/how-the-d-link-dir-825-router-connect-to-another-router.html
I then connect an Ethernet cable from my 8 port Netgear switch, to the D-Link LAN1 port.
The problem is the Router doesn't seem to think it has Internet, so I cannot update Firmware through the interface or get it to see a NTP server to update time/date.
If I connect my Phone to the Wi-Fi it's broadcasting, that is working.
• Disable UPnP™
• Disable DHCP
