Using dead H50 as GPU Block - Non Ref 460
24 Feb 2011
Any idea if this would work ?
I Killed the H50 in the process of building a full WC system.
I'd like to use the H50 Plate on my Palit GTX 460 SE Non ref board and was wondering if anyone had tried this before ? - Going to pull off the lovely stock fan/sink and and check sizes. If the H50 plate is a no-goer then I may also consider building a block around the stock hs.
I'll only be running at 1 volt anyway so not an extreme oc, just want some silence :)
Any help / guidance appreciated,
What's to lose, they certainly work on gpus with a bit of modding as a complete unit.
It'll be interesting to see how you go about cannibalising it though...
