using different GPU blocks
A little off topic but can you SLI a 6990 and a 6970? I thought for SLI or Crossfire to work both cards needed to be the same model?
i wouldnt try it tbh, you wont have a lot of space to work in and if the connection isnt solid, it could leak
cant you find a 6970 alphacool block?
OFFTOPIC:
with amd cards they dont need to be the same model, just be the same type so you can crossfire any of the 69xx cards: 6990 with 6970, 6970 with 6950, etc
OFFTOPIC:
Interesting I never knew that.
Back on topic:
I would also suggest trying to find a alphacool block, not only will they more likely line up but the asthetics of your rig will be nicer.
