- 6 Jan 2011
- Stoke on Trent
Hi, Just wondering if using a GPU outputting DVi and display port signals to run triple screen surround has any performance loss against running 3x display port? I was just thinking that the GPU has to create two signals of different protocols and this splitting between two jobs may make some sort of hit in lag and or FPS? Its not a question of is DVI or DP better what there outputs are ect, its a specific GPU related question about its output. I know when using DVI and HDMI is the same signal so that combination i would expect not too. Of course this is easily solved with a third DP lead but is it worth the bother?
