When I use easytune it does not save the changes? the save page is only on the advance mode screen, but when I save it neither saves the cpu speed or votage updates.
have just installed the Intel TAT problem? The DS4 Easytune gives temps of CPU 34 and the tat gives core0 53, core1 50?? Which do I believe?? Why such a big difference?
Yeah thats because Easytune takes its temps from the Socket, and the TAT takes them from the actual CPU cores, so both will be right, as they take them from different places, but go by the TAT ones for your CPU, my BIOS and Easytune says mines doing 28-30 (Socket), and Core temp says both my cores are 40-41.
