Using electrical wire instead of solder?
13 Jan 2012
United Kingdom
I need to attach wires to a switch but dont have a soldering iron at hand, is it ok to use electrical wire to stick it on instead?
It'll probably work but will not be a very reliable connection. If the switch tabs have a little hole in them you could try stuffing the wire through that and then wrapping around a few times and then holding in place with PVC tape.
Not reliable as in the risk of it detaching or something to do with the current? i could twist it around the tabs and then stick the tape over it and make sure its tight
