Using EyeInfinity
Don
23 Oct 2005
North Yorkshire
Hi guys,
EyeInfinity does impress me and I tend to use it for a lot of games, however some I prefer on the single monitor and also using the PC for browsing and everyday use I don't have EyeInfinity setup. I find it really annoying when disabling EyeInfinity as I have to setup my displays again, the default it comes out of EI is having the same display on each monitor, I then have to go into Display settings and start setting them up again to my liking.
Why does Windows not remember my setup? It just makes me think not using EyeInfinity would be a lot less hassle.
Grrr.
How do you guys find it?
If you're using all your monitors in your Eyefinity group, then just use Windows Key + P to switch between Extended (set up for separate screens) and Duplicate (Eyefinity setup). Once you've set up each profile, it works flawlessly after that each time.
Since changing from a 3 screen setup to 3+1, I can't do this as Windows recognises both my preferences as Extended (4x Extended screens and 3x Eyefinity + 1 Extended), so now I have two profiles set up in CCC. I have CCC pinned to the taskbar and simply right click on it, select the profile I want and it's done. This works well but with some drivers I've needed to select the profile twice for it to work properly and get my screens in the right places.
