I got a spare PC lyring around with these specs:
Intel Celeron 800MHz
256MB ram
CD Drive
4Mb onboard video
80GB IDE hard disk
I was thinking. Initially i was looking to buy a NAS drive to to hold files on the network but as you probably already know they do not come cheap, so i decided i might give FreeNAS a shot using just the 80GB for Data/OS for now.
I got a couple of questions:
Would you recommend FreeNas, or any other distro? Freenas looks easy to use, and this pc will not have a VDU.
Also, it will be connected to the wireless router via cat5 cable but the computers connected to this router are all via wireless. Would this result in slow file transfer speeds? or would it be for instance sufficient to stream divx files?
Thanks
256MB ram
CD Drive
4Mb onboard video
80GB IDE hard disk
Thanks
any idea's?
