Using HDMI output for sound only?
11 Jun 2003
Sheffield, UK
Looking at a few options for sound bars etc. I have a wee wall mounted cabinet right above the monitor so thinking to hang it from that to save desk clutter.
Just curious if bars with HDMI input would work ok plugged directly into a graphics card and using this as the windows sound output?
Usually run a GX6 with IEMs as my main output, after something I just switch from the taskbar speaker output rather than needing to go in a sound utility or similar so the graphics card output would be ideal if that generally works.
Yes it would work fine. Been using that solution for years until recently. You will get a "phantom monitor" representing the soundbar, it will appear as a second monitor in effect, no impact on actual performance however. Then just need to open sound and select the soundbar output as the active one and job done.
