Using installers…
26 Feb 2004
Hampshire, England.
Hey guys,
I’m a relatively new technical user of Linux, in the past I have just used it, but now I want to start playing :D
First up, how do I use installers? I want to install some “.tar.gz” but how to I find out their exact location for the terminal command, and what is the command I need to use etc.
Van anyone point me in the right direction or direct me to some good online recourses – it would be very appreciated ;)
Cheers,
SW.
Edit: I’m specifically referring to Ubuntu and SUSE.
In Ubuntu a LOT of programs are available via the Ubuntu repositories.
Easiest way in Ubuntu is to go to Applications > Add/Remove and you can search for what you want.
Alternatively, if you know the name of the package or program you want, you can open a Terminal and type:
sudo apt-get install package-name
This will find, download and install the package automatically. Some things arent in the repositories and you have to install/compile yourself. Pretty much every piece of software I have come across has had a README or INSTALL file that explains the steps required to install your software.
It is easier than you think :)
if the package ain't in the installers or you must get inside the tarball use this command
tar zxfv filename.tgz and that'll unzip it to the current dir.
