Using Linux as a Media Centre
24 Oct 2002
Cork, Ireland
Hi,
I've been using Ubuntu Intrepid as a media centre for a few weeks and am really pleased with it. I thought I'd share my experiences with you in case I can help anyone out.
I use VGA outputted to a HDTV and analogue 5.1 sound out via the 3 stereo outputs on my motherboard.
I watch a combination of DVD's, hidef MKV's and standard def AVI's.
I found that the standard video player (totem) was a bit choppy with hidef stuff and a bit thin on options. A bit of research tells me that Mplayer is the best quality and fastest player and has loads of options. I didn't much like the GUI so I settled on SMplayer which uses the Mplayer backend but is a bit more newbie-friendly.
SMplayer worked much better with the hidef stuff than totem and was easy to use so I stuck with it.
The big problem is that I could only get stereo sound. Ubuntu didn't seem to know about the rears, center, or the sub. After a search I find that Ubuntu's sound system is called Pulseaudio, but Pulseaudio only has 2 channels enabled by default. To enable all the channels I had to edit the file
~/.pulse/daemon.conf and create the line "default-sample-channels = 6".
After doing this I had 5.1 sound in the movies which had a 5.1 track - BUT on stereo files (including music) I had the stereo replicated across all 6 speakers which sounded rubbish. It seems that Pulseaudio will auto-upmix to all its speakers. To turn this off you need to add the line "disable-remixing=yes" to the daemon.conf. This left me with a setup which used the front 2 speakers for stereo output, but full 5.1 on the movies which had the full soundtrack.
Dolby Surround takes a regular stereo input and spits out 5.1. I know that many of my stereo movies are actually encoded with surround and hoped to be able to get this working. I found that there is a parameter called "surround" that can be passed to the audio filter in Mplayer which will decode the surround signal. Luckily there is a section in preferences section of SMplayer where you can set preferences and simply putting "surround" in the audio filter section makes this work.
So now I have 5.1 working for DVD's and MKV's that have it encoded in the usual formats, PLUS I have surround decoding working for my 2-channel files, PLUS stereo that does not have surround encoded only goes to the 2 front channels. This all sounds fantastic and was better than I ever managed in windows.
The video quality from Mplayer is flawless and I am very happy with it.
Hope some of this helps someone else.
yes im sure you can but this and would be useful for others that were wanting to push the audio out over SPDIF or something.. but for me splitting the stereo out in this way is dead easy and sounds great.
