Using MSI OC Scanner to overclock my 1080Ti
12 Jan 2009
I upgraded to a new monitor which is a higher resolution than my old one.
I've found its a bigger performance hit than I thought It would be. So I want to try and overclock my Gigabyte Aorus GTX 1080 Ti.
Last night I ran the OC Scanner in MSI Afterburner but my PC restarted during Test 2. What could be causing this?
I managed to manually overclock it by 25Mhz on the core and 200Mhz on the memory. Shall I set the voltage and power sliders to max and carry on increasing the core clock with 10Mhz increments?
Just a little update, managed to the the core clock to 2012 Mhz tbh I think that's enough for me as Rainbow Six Seige is running at over 150fps now!
Memory is still at 200+ but I think I'll leave that
