depend what ports are on the back of the tv but usually either a vga cable (if you graphics card is aslo vga u will have t o get a dvi to vga dongle) or a dvi cable or if it has neither of these then a scart to s-video cableBellboy said:Hi,
Dunno if I am being stupid here, but what do I need to be able to use my TV as a monitor for my computer?
depends on the size thoughultim said:i strongly advise against it. its very bad for your eyes unless its a hd tv![]()
yes that will be easily done with a scart to svideo cableBellboy said:Its a little sony widescreen tv, think its about 15 inches. I was just trying to find out if there was a way to do that cheaply so I didn't have to lug a 17" monitor all the way from chester to london on the train
Nm though we dug out some crappy trolley type thing to attach it to, so aside from looking a bit of an idiot it should be quite easy now.
