I hope your Vapextech batteries are better than the ones I got. They said 2900MAh on them but I'd say they were more like 1000MAh if that.
Don't worry though, I could have just got duff cells as other people seem to like them.
Terrible batteries - you'll be lucky to get more than 2200mah out of them and they';; self discharge in a week.
Eneloops or some form of LSD NIMH is the only way to go for rechargeable batteries.
Well, I won't be buying Vapextech again. I used four batteries out of the eight I bought and put them into a small lamp with a sensor that turns the lamp on when someone is near. They lasted much longer than my previous batteries. But when I went to charge them in my Uniross 15 minute charger, only two of them charged fully and the other two appear to be dead already. None of the four lights flash on the charger (which is indication of each battery charging) regardless which charging slots I put those two batteries in, and this is the first time I've tried to recharge them. I questioned my charger which is quite old now, but I think it's still working ok as other batteries seem to charge fine. I'll buy some Eneloops.
This happened to some other batteries of mine, when they wouldn't charge and a day or so later they charged. It must be something to do with the charger.
. You should be looking at around 1A for maximum number of cycles. It will take a couple of hours to reach full charge but it's safer and will prolong the life of your batteries.
