Now I've pretty much finished upgrading my PC I'm planning on using the old parts as the guts for a media PC. The plan at this stage is to run XP 32bit on the existing HDD (74GB WD Raptor) and get a second HDD - 1 or 2TB - to burn all my DVD's on to. I'm also looking to get some sort of Blu-Ray drive.
The mobo is an Asus M2N4 SLi:
http://www.asus.com/product.aspx?P_ID=Tiqsh7TlDIG7JbO3
The CPU is an Athlon X2 3200/3400, something like that and theres 4GB of branded DDR2 RAM in there. The GPU is provisionally looking to be my existing 9500GT, and if practical I'll be transferring over my Corsair CX 400W PSU.
Oh, and the TV it'll be connected to is a Panasonic TXP42G10.
Now I start to get a bit confused. As I understand it the first hurdle is going to be the motherboard - if I want a case that will be smaller than midi tower I think I'm going to have to look at a new motherboard?
Which leads on to the case. I guess I want an HTPC case of some description, although it had crossed my mind that I could alternatively use a small normal case and use my HTC Desire and wireless software to control it. Is that an option or should I just look at an HTPC case specifically for the job?
Something like this:
http://www.overclockers.co.uk/showproduct.php?prodid=ca-060-an&tool=3
then theres the connection question. the tv doesn't have a dvi in slot from what i can see, so something like this would do for the picture:
http://www.overclockers.co.uk/showproduct.php?prodid=cb-018-ok
but how would i get sound across as well? tv connection stuff goes over my head.
full tv spec's here:
http://www.panasonic.co.uk/html/en_...ecification/6269268/index.html?trackInfo=true
Cheers in advance for any help anyone can offer.
