Hi guys, I've found the garage has an ethernet connection (shielded etc) but that's not going to any connection in the house. It is, fortunately, laying on the ground next to where the BT fibre goes through the brick wall and into the understairs cupboard to connect to the ONT.
My question is, if the hole is big enough, can I run the ethernet cable through the same hole without borking the fibre connection? I'm confident enough to throw an end on it once inside. Alternative is drilling another hole in the outside wall (which I'd rather not do).
