I was looking into peltiers and read that they could be used as generators and I was thinking if used a cpu waterblock, a peltier and then some kind of cpu air cooler and sandwiched together:
waterblock
peltier
air cooler
would it not be possible to generate a current from the heated water and then power a fan which cools the air cooler and so keeps the temperature gradient high enough?
the only problem i can see is that the water may not be hot enough and the heatsink on the opposite side may not be cold enough so only a small current will be generated
waterblock
peltier
air cooler
