Using 'remote' on iPhone and home sharing
30 Dec 2003
Bigger box!
Right...
I've recently built a new rig and as such have copied my iTunes library over onto the new rigs HDD.
I still have the old rig set up and have since discovered the joys of 'Home Sharing'.
I've got iTunes remote set up on my phone and am able to control each computer no problem.
However, because my 'main' library is now on my new rig, that's the one that's set to update podcasts etc and therefore has stuff on it that my old rig doesn't.
If I play stuff from my new rig using home sharing on my old rig, I am unable to control the old rig with remote.
Any ideas if it's possible and if so how??
Cheers :)
P.S. Just a minor point, using home sharing, I can access all files no problem, but none of the artwork carries over and all of the different 'views' (the four buttons between the main display and the search bar at the top right of the iTunes window) are greyed out. Is this normal??
Ta again :)
