Using Roccat Kave as 2.1?
22 Jun 2011
Stoke-on-Trent
Hi.
I am looking to buy a gaming headset. I will be using it with an iMac.
Of course, you can only use 2.1 sound on an iMac because it only has 2x 3.5mm jacks (unless you use optical)..
I am thinking of buying the Roccat Kave (5.1 Sound)
http://www.roccat.org/Products/Gaming-So...-Kave-5-1/
However, If I buy the 5.1 headset ^ and only use it as a 2.1 will I still get the performance of a 2.1 headset or will it be reduced because it was designed to be used as a 5.1 etc...
Thanks.
Why bother?
As others have already said either buy a 5.1 headset based on USB or ignore 5.1 and just get a set of 2.1 headphones.
Buying a 5.1 headset and only using it on 2.1 source is daft, you get the worst of both worlds, poor 2.1 performance and paying £ for something you can't use.
Why bother?
5.1 on USB would require drivers (I think) and most of them don't support MAC OS X.
So it is true, 5.1 on 2.1 is not as good as normal 2.1 headphones?
Also the Razer 2.1 headphones and the Roccat 5.1 are roughly the same price.
2.1 speakers are 2 speakers and a subwoofer. 2.1 headphones are, in my opinion, a complete con. They won't offer anything over a quality pair of ordinary headphones. Save your cash and buy a pair of quality cans instead.
I am looking at the Logitech G35's. They use a USB and even though it does not have drivers to support MAC OS X I can boot camp in Windows and use the 7.1 surround sound when playing games and standard stereo on MAC OS X .. now just to see if the microphone and noise cancellation requires the drivers to function..
