Using sed or perl to replace multiple lines with leading spaces?
Commissario
16 Oct 2002
In the radio shack
Hi folks.
I'm not a programmer but I can manage to do many things simply by looking into the command formats and working it out but this is causing me an issue. I'm trying to replace multiple lines in a .js file which have leading spaces but can't manage it with either sed or perl
This is what the source looks like
And this is what I want it to be
I need to change the 000000 to 0000DD, add a new line with lineDash below it and change the width to 2.
I can't just search for 000000 and change it to 0000DD because there are more than one instances of that within the file and the same goes for the width. There is only one instance of var ringStyle so that's the point I have to start with.
I've spent the last couple of hours trying padding the perl command with spaces and using \n for the line separators just to try and get this done but I'm failing badly. I'm sure there's a way to do this but I'm hotspured if I can work it out. I've got the command in a format which doesn't error at me any more but it doesn't actually do anything! Here's what I'm trying (this is a long command with the correct number of spaces). This is just to try and replace the 000000 with 0000DD and then I was going to tack the extra bits on the end.
Code:
sudo perl -i -0 -pe 's/\Q                var ringStyle = new ol.style.Style({\n                        fill: null,\n                        stroke: new ol.style.Stroke({\n                                color: '#000000',\n\E/\Q                var ringStyle = new ol.style.Style({\n                        fill: null,\n                        stroke: new ol.style.Stroke({\n                                color: '#0000DD',\n\E/g' script.js
Can anyone help please? If so, please can you explain the format of the command so I can understand what I'm doing.
Thanks.
What he is saying is that to run the JS code with crap formatting will be fine. The whitespace is just to make it easier for you.
You can fix any whitespace issues after solving your problem by using a linter. This will reformat the entire file for you to look pretty.
perl -0777 -i.original -pe "s/'#000000',\n\s*width: 1/'#0000DD',\nlineDash:[4,4]\nwidth: 2/igs" derpy.js
derpy.js is your input file and will also be your output file.
your original is copied to derpy.js.original
The above replaces
Code:
with
Code:
where \s* matches any amount of whitespace before the width statement (this could be why your attempt failed as you hardcoded X spaces)
\s is whitespace (tabs and spaces)
* is 0 or more
sed is designed for line by line processing unless you delve deep into its scripting functionality which is why it will not match any commbination of stuff with a newline in the middle.
Thanks. This does work, sort of. The trouble is that there are multiple occurrences of the color and width entry within the file and I only want to change the one in the var ringstyle section.
With the example you've given, I thought it would be simple enough to build in the lines above to the command but it's not proving as straightforward as I though. Even just adding the whitespace to the color line isn't working.
One step at a time. First I added the whitespace and the additional text at the start of the color line.
perl -0777 -i.original -pe "s/\s*color: '#000000',\n\s*width: 1/\ncolor: '#0000DD',\nlineDash:[4,4],\nwidth: 2/igs" derpy.js
Works fine.
Then when I get to the next line, I'm introducing characters that are included in regex so I knew I was going to get problems.
perl -0777 -i.original -pe "s/\sstroke: new ol.style.Stroke({\s*color: '#000000',\n\s*width: 1/\nstroke: new ol.style.Stroke({\ncolor: '#0000DD',\nlineDash:[4,4],\nwidth: 2/igs" derpy.js
doesn't work because of the ({ characters.
Unmatched ( in regex; marked by <-- HERE in m/\sstroke: new ol.style.Stroke( <-- HERE {\s*color: '#000000',\n\s*width: 1/ at -e line 1.
I think I need to use \Q and \E as start and end terminators to enclose the ({ but this is where I'm struggling now.
I've been playing with this for an hour this morning and now I have a headache!
Code:
perl -0777 -i.original -pe  "s/ringStyle.*\}\)/ringStyle = new ol.style.Style\(\{\nfill: null,\nstroke: new ol.style.Stroke\(\{\n color: '#0000DD',\n lineDash:[4,4],\nwidth: 2\n \}\)/igs"  derpy.js
You needed to escape your brackets and braces with a \ (on both your input and output)
This command replaces
Code:
ringStyle.*\}\)
With whatever
Where .* matches "anything" 0 or more times
followed by a single brace and a single bracket
This only matches . with \n because of the /s at the end of the command that makes perl think the entire string is one line when it is not.
I havent used this tool https://github.com/beautify-web/js-beautify but it looks like it would tidy up your code for human readability. It seems to have a web gui if you dont want to use the command line and its active so has been updated recently.
Thanks, we're so nearly there!
There are other instances of ringstyle within the file so running that command does what is needed on the first instance but destroys the file following the second instance. I've tried removing the g from the /igs but that doesn't seem to stop it. The file goes from 1900 lines long down to a little under 800.
It's also behaving a bit funky. I can see exactly what it's supposed to be doing. As you say it looks for ringstyle and then replaces everything between ringstyle and }) with the following text. Except that it's not quite right.
It does as it's supposed to but then truncates the next line from }); to a single }
It goes from this:
to this
Which it shouldn't do.
Here's the exact command I'm running
Code:
perl -0777 -i.original -pe  "s/ringStyle.*\}\)/ringStyle = new ol.style.Style\(\{\nfill: null,\nstroke: new ol.style.Stroke\(\{\n color: '#0000DD',\n lineDash:[4,4],\nwidth: 2\n\}\)/igs" derptastic.js
If I change the final 2\n\}\) to be 2\n\}\)feek then the output above will have })feek on the penultimate line and the last line will be }
:confused:
I have not tested this one as im omw out but try this.
Code:
perl -0777 -i.original -pe  "s/var\s*ringStyle.*\)\};/var ringStyle = new ol.style.Style\(\{\nfill: null,\nstroke: new ol.style.Stroke\(\{\n color: '#0000DD',\n lineDash:[4,4],\nwidth: 2\n\}\)\n\}\);\n/igs" derptastic.js
It replaces the entire
Code:
var ringstyleSTUFF)};
with
Code:
NEW STUFF
and then puts an extra newline on the end
This should alter every instance of ringstyle being declared in the file but will not touch the assignments.
Thank you. It runs, creates a backup and exits without any errors.
But doesn't do anything to the file. I feel we're really close though.
I just ran it on test file containing
Code:
derpy derp derp derp her
herp derp s derp
        cheese;
                fill: null,
                colour: '#000000',
                width: 1
        cake;
and it produced this
Code:
herp derp s derp
        cheese;
fill: null,
 color: '#0000DD',
 lineDash:[4,4],
width: 2
        cake;
If its not mathcing for you and giving no errors then the input pattern is wrong
Code:
I cant see any way to make this any simpler and still match. Also I think this pattern is too loose and is matching too much and replacing extra stuff.
Sussed it - Well partly.
The brackets were the wrong way round in the command. I've corrected that and it runs. I now go from:
Code:
                        fill: null,
                                color: '#000000',
                                width: 1
to
Code:
fill: null,
 color: '#0000DD',
 lineDash:[4,4],
width: 2
But. See that there's a final } there.
My new file is 787 lines compared to 1907 for the original. That } has not been appended by the command, it's just at the end of a huge chunk of code that's been removed.
Yes. We're nearly there, it's just this bit.
Code:
perl -0777 -i.original -pe  "s/var\s*ringStyle{1}\s*=\s*new\s*ol\.style\.Style{1}\(\{\n\s*fill:\s*null,\n\s*stroke:\s*new\s*ol\.style\.Stroke{1}\(\{\n\s*colour{1}:\s*'#000000',\n\s*width{1}:\s*1\n\s*\}\)\n\s*\}\);{1}/var ringStyle = new ol.style.Style\(\{\nfill: null,\nstroke: new ol.style.Stroke\(\{\n color: '#0000DD',\n lineDash:[4,4],\nwidth: 2\n\}\)\n\}\);\n/igs" derpy.js
fixed by making sure there were no
Code:
and also using
Code:
{1}
to make sure we match against only 1 occurence of a literal string.
Rock and Roll Saturday night, HashBrown Perl - Living The Dream
Thanks. I did have a quick look after you posted that last night but didn't do anything with it as I was full of beer! This morning I've had a good breakfast and am back on the case.
No error.
No change in the file. Which means that it's not finding a match.
To test further, rather than run it over my original source, I've created derpy.js and put this into it:
Code:
                        fill: null,
                                color: '#000000',
                                width: 1
Run the command
Code:
sudo perl -0777 -i.original -pe  "s/var\s*ringStyle{1}\s*=\s*new\s*ol\.style\.Style{1}\(\{\n\s*fill:\s*null,\n\s*stroke:\s*new\s*ol\.style\.Stroke{1}\(\{\n\s*colour{1}:\s*'#000000',\n\s*width{1}:\s*1\n\s*\}\)\n\s*\}\);{1}/var ringStyle = new ol.style.Style\(\{\nfill: null,\nstroke: new ol.style.Stroke\(\{\n color: '#0000DD',\n lineDash:[4,4],\nwidth: 2\n\}\)\n\}\);\n/igs" derpy.js
No change.
It looks to me as though it should work, the format looks right. I'm stumped.
Ok. I have spotted the problem. Its a common one when programming. I am not running my JS code which is why I did not hit it.
You need to remove 1 character from the input pattern.
Here is a clue.
Aww man, I've spent more time examining that than a sixteen year old spent studying the underwear section of the Grattan catalogue in the early 80s looking for a hint of areola :D
I can't find it and the clue didn't help (although I did waste half an hour looking at old adverts).
Your code uses the american spelling of color. In my test code and my fix I used the queens english spelling of colour.
Alter the fix so that the input pattern uses "color" instead of "colour".
I have just tested on a massive test file with random indents and repeated matches and it works ok.
Code:
perl -0777 -i.original -pe  "s/var\s*ringStyle{1}\s*=\s*new\s*ol\.style\.Style{1}\(\{\n\s*fill:\s*null,\n\s*stroke:\s*new\s*ol\.style\.Stroke{1}\(\{\n\s*color{1}:\s*'#000000',\n\s*width{1}:\s*1\n\s*\}\)\n\s*\}\);{1}/var ringStyle = new ol.style.Style\(\{\nfill: null,\nstroke: new ol.style.Stroke\(\{\n color: '#0000DD',\n lineDash:[4,4],\nwidth: 2\n\}\)\n\}\);\n/igs" derpy.js
Oh for goodness sake! :D :D
Yes, you're right. I've tested it and it's perfect. Thanks so much for your help and I've learned from it as well.
