Hey all
mods: Not really sure if this is the right place, but if not, feel free to move it.
I was just wondering if Sky+ can be used to record programs in a way that can be put onto a computer at a later date?
I've been messing about with the idea of getting a tv card but I'm a good way from the Sky box, so any signal out has to travel down a long wire (svideo or coaxial) and obviously the quality doesn't get any better.
I believe there's a USB connection on the back of the Sky+ boxes so what would be to stop you hooking an external in and extracting the contents of the drive? I understand there's a bit of software that does this automatically.
It might not be simple or even possible (if Sky records the programmes in a cryptic file type that only the box can read) but was just wondering if anyone had any idea.
Thanks.
Thanks.
