- 4 Nov 2003
- Edinburgh
Is it ok to use tap water through my reserator just to check theyre arent any leak issues with the reserator itself. No water blocks themselves will be used, just the pump and resivour.
I know extended use isn't good with tap water, but what if i just use it a few times, then put the distilled water and wetter in, surely that will be ok?
The problem is the outlet connection on my res was broken and i only noticed after i put all the rest of the kit in the PC, so i've glued it back on (pretty well i think) and it seems sealed but i dont want to have to waste distilled water (well i dont even have any to hand) to check it.
So i wont damage or leave any residue in the pump will I?
) worked a treat. SO much stuff flew out. Don't do this thought until somebody tells you white spirit doesn't corrode plastic, it might.
Wish i'd checked it BEFORE i put the water blocks and cut the tubing to perfect sizes etc...
