Hello!
Very frustrating issue with my BT extension sockets. If using the two extensions rather than the master I get disconnected as soon as the phone line is enabled.
So my router > filter > extension socket. Pick up phone and press to start call.. as soon as the dial tone is heard my broadband connection drops.
If the router is connected via master with a filter it is fine. I've tested using a constant ping and it's perfect.
How do I go about fixing the extensions without having to fully re wire if possible?
Could I potentially remove the faceplate and check/fix?
I'm trying to avoid having someone come out and re wire or use a super long RJ11.
Thanks in advance.
Thanks in advance.
