- 24 Feb 2004
- Leeds/Cyprus
OK, I don't really understand the readings on this thing. When I plugged in just the 24-pin plug, it reported the second 12V rail as too low. Then the penny dropped and I plugged in the 4-pin plug as well, and both 12V rails were within spec. However, on the far right edge of the screen there was the message "PG=0ms" and I have NO IDEA what that means!
I just wanted to test my SATA power cable tbh, because I've been finding errors on my HDD and I suspect it's due to insufficient power to them, but it doesn't seem to be able to test a single power cable alone. With the 2 main motherboard connectors plugged into it, plugging my SATA cable into it made no visible difference to the readings on the screen - how do I test that alone?
