Caged said:Do you know what DRM is?
From what you're saying, you clearly don't understand what it is.sajtion said:well yeah i wouldn't be asking the question if i didn't know. i believe the term stands for digital rights management and it clearly shows on the quality of my movies. i've read about it thoroughly on wikipedia and btw i saw this article here and thought microsoft should do same for vista
modo77 said:about 6 months ago
sajtion said:when will you start using vista?
sajtion said:i personally will when microsoft releases update that removes drm completely
So you don't want to be able to play HD-DVD or Blu-Ray (or DVD for that matter, seeing as that uses CSS), or buy non-EMI music from a music store? Or play any games which use copy protection any more advanced than a simple CD check?sajtion said:well yeah i wouldn't be asking the question if i didn't know. i believe the term stands for digital rights management and it clearly shows on the quality of my movies. i've read about it thoroughly on wikipedia and btw i saw this article here and thought microsoft should do same for vista
http://www.theinquirer.net/default.aspx?article=38783
