Hi,
I am thinking of switching to a widescreen for my PC and I'm looking into getting one of those LCD/TV hybrids. Are games effected by widescreens? Also, do you get as good a picture using a HD TV for your monitor as you would a normal TFT? Are there any other issues I should be aware of?
Second question:
I have a 8800 GTX card, what sort of input to the TV would I need? This was one of the models I am looking at:
http://forums.overclockers.co.uk/showthread.php?t=17785751
Display
Diagonal Size 22" - widescreen
Dot Pitch / Pixel Pitch 0.282 mm
Max Resolution 1680 x 1050
Colour support 24-bit (16.7 million colours)
Max Sync Rate (V x H) 75 Hz x 81 kHz
Response Time 5 ms
Display Positions Adjustments Tilt, Fold
Video Output TV tuner
Features Picture in picture, OSD-Digital Display Director, picture by picture, MagicBright 2, MagicTune, MagicSpeed, MagicColor, HDCP
Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15)
1 x DVI-D - 24 pin digital DVI
1 x SCART - 21 pin SCART
1 x HDMI - 19 pin HDMI Type A
1 x S-video input
1 x component video input
Thanks for your time!
Second question:
Display
Response Time 5 ms
1 x S-video input
