Using Wii RGB Scart AND Still Getting 5.1 Sound - How?
31 May 2005
Nottingham
Can I get a "pass thru" type scart which I plug into the TV which the RGB scart connects to, however also has 2x Composite audio connections to pass to my Amp or a Digital output?
If a device exists, it will need to support RGB and retain the 5.1 sound.
Many Thanks, hope that makes sense.
I want to retain the RGB scart, yet somehow connect the sound to my AMP.
Thanks.
£3.50?
Can you say where?
I'll search Google.
Does it Support RGB?
My understanding is that not all breakout boxes support RGB?
I got it ages ago so can't say really.
All pins are wired and there is a switch on the breakout box that simply puts the 2 audio pins into the TV or to the phono plugs on the side.
Edit: Fully supports RGB. My TV states the mode it's displaying and there is a clear differenc ebetween composite scart and RGB.
Edit 2: Yes, not all output RGB. Mine only breaks out the R/W phono connections and not the S-Video/ composite connections etc.
Need something like this:
BUT is needs to support RGB.
Anyone have any links?
