my new pc has an Asus M2N32-SLI deluxe motherboard with an integrated wireless card. i installed the included software and it works really well, but with no security on the network.
then i decided to put WPA2 encryption on (AES, pre-share-key) and it worked fine when i put it on, then it bluescreened about 5 seconds later.
the bluescreen identified the cause of the problem to be the Asus WiFi process, and when i restarted the computer, it bluescreened as soon as the WiFi app loaded.
i went into safemode and turned off the security, (on the card and network) and now everything is fine.
anyway, just running good ole' XP pro SP2.
anyway, there are a fair few people "borrowing" my connection, so any help here would be hot.
