- 18 Oct 2002
- Somerset
Evening
Having found a few posts through the search option of people on here running UT servers i have decided it is time to post in an attempt to find some help.
i am trying to run a UT and UT2004 server from home for a small group to use while some 'old friends' are all back in the same area.
Problem is i cant get either working
I started with UT, downloaded the dedicated server files and ran the set up,
Found the .ini file and adjusted what needed doing (as far as i know?)
Got into my router and forwarded a load of ports from a list i found online,
Ran the 'Start UT server' in the start menu.
It starts up and goes through its stuff,
Gets to a point where it can connect to the master server.
From my understanding all 3 of the master servers in the .ini file are no more?
unreal.epicgames.com
master0.gamespy.com
master.mplayer.com
Ping on the first two gives destination host unreachable, the last gives host can not be found.
So the server is never going to connect to them ?
Do people change these or remove them from the .ini and forget about master servers?
They are only needed to advertise the server? and i don't need it advertised i will just give my external IP to the people that will be playing.
Well to test this i had the server running and loaded my game up (same PC)
the server shows and players under the LAN tab, Yah happy me
Gave my external IP to some one and the loaded up and stuck that into 'open location' it goes to the next screen as though it is loading but just sits there doing nothing.
I have spent hours looking over very old articles and forum posts on the net but just have not got any where.
Now when i click 'start UT server' dos box flashes up for a few seconds then it is gone, think i broke it good this time,
Will look at deleting it and starting again i think,
Going on to UT 2004 i also get master server connection problems with that, have gone no further than starting the server with that yet, one at a time i think.
If any one can help me get this running you would make a small group of people very happy for a few weeks
master0.gamespy.com
master.mplayer.com
