- 28 Jun 2005
- Behind you
Hi,
UT3 and Gears of War both wont get past the splash screen on my PC in sig. All 4 cores are in use but nothing happens, it just hangs at the splash screen till I end task. I have patched both games too. Aby ideas?
Ta
Ta
I tried without AV and Razer software just to see if they were conflicting but still no luck. The thing is ut3 used to work.
