UT3 Framerate Question
I'm currently playing UT3 on the rig in sig, at 1280 x 1024 (Viewsonic VX922) at 75Hz, and noticed via 'stat FPS' that my framerate dips well into the 40's at times, certainly on the Deck map, when you get a large open expanse with some action, it does judder, and the FPS is 40-something. I'm running 4x AA via CCC (Box) and AF (and everything else) at max via UT3 settings. I'm running vSync, and have upped the 'maxsmoothframerate' (or whatever it's called) to 77 to go with my higher vsync speed. Framerate smoothing is turned on as well.
What is causing these drops? I'd hoped this setup could cope with UT3 at my res no problem...
Or am I expecting too much?
Any ideas are welcome...
