Hi Folks,
I recorded a game of UT3 with FRAPS to watch back and having watched it I found a few things that don't seem right. I'm not sure whether this is lag from playing online (although my ping isn't often more than 30) or something wrong with my settings or something that needs to be changed in my ini files.
See the following pictures for an example I found from my video. These are screens taken from the video played frame by frame in media player. The crosshair is a bit hard to see because of the compression etc.
Starting to line shot up
Pull trigger with crosshair over head.
Shot travels straight through head!
Shot is still showing as travelling through enemy. Not once does the crosshair turn red (i presume it is red when it is over an enemy)
Is this due to lag and what I am seeing is slightly behind what is actually happening or is there something else to it, a setting somewhere.
I am on virgin media 2mb cable and have my internet settings set to cable modem and no dynamic net speed. Is there anything in the ini's I can change to help my shots register.
Thanks
Matt
PS. Ignore the FPS in the top corner, not sure why it only shows 1fps and 0 fps :-/
Thanks
Matt
