UT3 PS3 keyboard and mouse
24 Aug 2006
Hi PS3 owners
Just wondering if any of you have got UT3 and have tried playing with keyboard and mouse?
How does it compare to PC play?
Is this revolution in console gaming?
I've played both the PC Demo and PS3 Full Game (Tested on Shangri-La) with Mouse and Keyboard, I can see no obvious differences between the two other than the PC being able to go to higher resolutions. Mouse and Keyboard surprisingly feels the same on both, tested with an Apple Keyboard and MS Intelli V3 Mouse.
Is it a revolution in Console Gaming? No because you could play Quake3 on Dreamcast with Mouse and Keyboard, and also I'm not a big fan of differing control methods on the same platform, the mouse/keyboard players are going to pwn those on pads. At least you can go on a 'Pad Only' or 'Keyb/Mouse Only' Server should you wish.
Quake2 on PS1 had mouse support. This worked really well for aiming and joypad in the other hand for movement and other functions. id like to see similar added to more console fps. Im trying to enjoy warhawk but i just cant grasp having allthe functions on the joypad. back to pc ut3 for abit i think ;)
My gripe with UT3 keyboard/mouse is that if I used my wired keyboard/mouse on it I'd have to be up close on the screen, 720P titles look crap close up on big TV's :(
Doesn't really matter though, run the PC version @1080p looks great, might get it on PS3 for the ability to sit back and play though.
I'm getting more and more attracted to buying this, I think it's rp2000 if I'm being honest. I bought the PC version and it was okay, more of the same which isn't bad, but I expected more, however I do think I'd enjoy it on a console. Dunno which one to get it on though.
